Date/Time: Fri, 03 May 2024 02:35:55 +0000
Automated File Distribution System
View Count: 530
[2019-09-17 09:29:31] |
User740266 - Posts: 26 |
I have read that using the "Automated File Distribution System" function, the compiled code in a custom studies DLL file cannot be reverse engineered. Does it mean that if I need to distribute an indicator to others, it is better to use the above method instead of directly giving a dll file to them in order to protect my intellectual property? Is there a difference? |
[2019-09-17 11:41:11] |
There is no difference. But you are going to save yourself a lot of hassle by using our automated file distribution system.
