Date/Time: Thu, 02 May 2024 15:51:35 +0000
Sierrachart/stage 5/rithmic ... is there a way to close my positions on my mobile?
View Count: 1329
[2019-09-17 04:27:25] |
User348929 - Posts: 16 |
Hi, I'm trading with Sierrachart/stage5 and rithmic. I really need a solution to close my positions from my mobile in case something goes wrong on my computer. I hope someone has a solution... Thanks a lot and best regards, Corinne |
[2019-09-17 11:35:38] |
This is not supported unless Rithmic has a mobile application for this . You can check with them. Although this capability is being developed for this service: Sierra Chart / Trading Technologies Futures Order Routing Service The above linked order routing service is different than Rithmic. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-17 11:36:53
