Date/Time: Thu, 02 May 2024 17:27:08 +0000
Trade DOM
View Count: 894
[2019-09-16 18:33:20] |
User982736 - Posts: 46 |
Your documentation shows a Trade DOM standalone window, but I can't find a way to bring it up. I can show the Chart DOM fine. Thanks. |
[2019-09-16 22:49:06] |
File >> Open Trading DOM for Chart is the fastest way if you already have an open chart. Refer to the following documentation for this and other methods to open the Trade DOM: Chart Trading and the Chart DOM: Trade DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-09-16 23:07:40] |
Thanks. I thought all the trading stuff was under Trading.
