Date/Time: Thu, 02 May 2024 19:44:49 +0000
date reange
View Count: 874
[2019-09-16 18:09:41] |
Krodrigues - Posts: 2 |
How can I upload different Date Range: 1/5 days 1 /3/6 moths YTG / 1 year = to show in main screen with one click ? thanks |
[2019-09-16 22:45:15] |
We are not understanding this. It is not clear what you want to do. What do you mean by "upload".
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-16 22:45:25
[2019-09-17 03:28:24] |
Sierra Chart - Max - Posts: 5598 |
From user: how to place or include the date range or time frame that comes automatically in other platforms: 5 - 15-10 50 minutes / e=3m / 6m YTD/1 Y /@Y / 5 Y how can I choose a couple of those options and list on my control bar - so who I click it would show the entire period chosen in the screen ? tks Sierra Chart Support |
[2019-09-17 11:29:34] |
Refer to this page: Changing Chart Bars Period That page also explains how to set up Control Bar buttons for custom time periods per bar. To control the date range in the chart, refer to: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#UseDateRangeFromTo Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
