Date/Time: Thu, 02 May 2024 15:10:57 +0000
How to transfer current settings/configurations to a new computer?
View Count: 952
[2019-09-16 17:51:56] |
ComingHome - Posts: 18 |
SC: How do I transfer current settings/configurations to a new computer so that I don't need to do it all manually? What files do I need to copy from my current Sierra Chart settings/configurations (old computer) to a new installation (new computer)? Thank you in advance for your help ! |
[2019-09-17 11:54:37] |
Refer to help topic 15: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
