Date/Time: Thu, 02 May 2024 21:13:44 +0000
Enter text box pops up
View Count: 739
[2019-09-16 16:36:43] |
User619571 - Posts: 6 |
Every time when I click on the chart the enter text box pops up. Thanks |
[2019-09-16 17:12:40] |
You have one of the Type Text tools selected in the Tools pulldown menu. Select a different tool, or Pointer (which is the tool that has the most limited functionality). Refer to the following: Chart Drawing Tools: Tools Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
