Date/Time: Thu, 02 May 2024 22:14:47 +0000
v.1987 commissions not being reflected on some chartbooks in NPL
View Count: 504
[2019-09-16 15:34:10] |
User753428 - Posts: 158 |
in some chartbooks, commissions are correctly reflected in NPL whereas in other chartbooks, no commissions are applied. within trade activity, commissions are applied correctly. i'm just talking about the NPL display on the top left of the main chart. |
[2019-09-16 16:52:58] |
Refer to this setting: Chart Settings: Use Symbol Commission Setting in Trade List and Statistics Calculations (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
