Date/Time: Sun, 24 Nov 2024 21:20:53 +0000
Data download issue
View Count: 1210
[2013-12-12 13:05:24] |
Hendrixon - Posts: 130 |
Yesterday installed a new copy of 1061, set it to download 2 days of data at 1 tick. I opened a chart for ESZ3 and SC started downloading data from september... It downloaded the *whole* contract at 1 tick which came to 950MB. Downgraded to 1038, deleted the scid file, downloaded ESZ3 again and got 2 days of data. |
[2013-12-12 17:43:19] |
Yes, this is true. 100 days minimum is downloaded to ensure the user gets a significant amount of data or all of the data for a futures contract. The only exception is when unreliable historical data services are used. Such as with Interactive Brokers. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
