Date/Time: Fri, 03 May 2024 02:14:33 +0000
Daily Chart
View Count: 481
[2019-09-16 11:22:21] |
Jeffrey S - Posts: 42 |
My daily chart is not showing the correct low
[2019-09-16 12:21:39] |
Refer to this help topic: Data Errors or Spikes in Charts, Flat or Flat Line Graph, Compressed Graph, Errors with Date/Time Values: 2.2 Historical Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
