Date/Time: Fri, 03 May 2024 01:43:10 +0000
Pivot point daily study is showing pivots for previous days
View Count: 1185
[2019-09-16 02:22:54] |
User643046 - Posts: 14 |
Hello, See attached screen-shot. I only need the pivots shown for the current day however, the study shows it for past many days. It makes the chart very messy as you can see in the attachment. How can I fix this? tx K |
Pivot Point-Daily study chart.JPG / V - Attached On 2019-09-16 02:22:35 UTC - Size: 121.68 KB - 440 views Pivot Point-Daily study settings.JPG / V - Attached On 2019-09-16 02:22:41 UTC - Size: 144.74 KB - 287 views |
[2019-09-16 15:59:25] |
Set the input for Number of Days to Calculate to 1. Refer to the information for this input here: Pivot Points: Number of Days To Calculate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
