Date/Time: Mon, 06 May 2024 02:02:58 +0000
Hand tool setup
View Count: 2114
[2019-09-15 21:01:06] |
Dom7364 - Posts: 257 |
Hello, how do you setup the hand tool so it does move chart left and right as well as up and down please? Thanks |
[2019-11-06 14:16:47] |
User766870 - Posts: 3 |
The Hand tool can be used for vertical movement and scale changes. To enable this, select Global Settings >> Tool Settings >> General on the menu. Enable Support Vertical Movement/Scaling with Hand Tool. Chart Drawing Tools: Vertical Movement and Scaling |
[2019-11-06 16:36:37] |
Yes this is the relevant documentation for this: Chart Drawing Tools: Vertical Movement and Scaling Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
