Date/Time: Sun, 02 Feb 2025 12:54:11 +0000
Fixed Delta
View Count: 621
[2019-09-15 14:51:08]
John Ara - Posts: 125
Please let me know how to set charts based on a fixed amount of delta in each bar?
Thank you.
[2019-09-15 15:09:41]
Chris_uk - Posts: 89
Under Chart Settings select 'Delta Volume Per Bar' as the Bar period type, you can then put the desired value in the 'Setting' field.
Cheers
Date Time Of Last Edit: 2019-09-15 15:10:24
[2019-09-15 16:11:36]
This is a Chart Setting. Refer to:
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#TimePeriodPerBar
And here is the specific Intraday Chart Bar Period >> Bar Period Type:
Chart Settings: Intraday Chart Bar Period >> Bar Period Type >> Delta Volume Per Bar
