Date/Time: Thu, 02 May 2024 19:35:16 +0000
Chartbooks
View Count: 1475
[2019-09-15 07:23:51] |
User845232 - Posts: 4 |
Hello When I open the Chartbooks I want them to be appeared in a specific order. FOR example: I have 3 Chartbooks that are named: a, b, c. When I open the Chartbooks they are appeared in this order: c, a, b. How do I set the Chartbooks to be appeared in this order: a, b, c? |
[2019-09-16 15:34:45] |
John - SC Support - Posts: 31328 |
You just need to set the order in Global Settings >>General Settings >> Files to Open on Startup. Put the Chartbooks in the order you want them lined up, from top to bottom. Refer to the following: General Settings Window: Select Files to Open On Startup (Global Settings >> General Settings >> General >> Startup) After you have the Chartbooks opened, if you want to reorder them, you can just grab the tab and drag and drop it into the position you want. Refer to the following: Chartbooks (Workspaces): Reordering Chartbook Tabs For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-19 07:31:13
