Date/Time: Thu, 02 May 2024 20:12:19 +0000
Gan fan-value incremnt per bar in ticks.
View Count: 568
[2019-09-15 00:22:36] |
User256311 - Posts: 11 |
hello SC, I have looked at all your content regarding Gann Fan but I still can't draw a simple 1x1 angle that is remotely close. the problem may be the value increment per bar in ticks I am using. could I please request an example on the s& p 500 daily? I understand this is most likely human error but I have has some much smarter minds then me look at this and can't seem to get it to work either. Kind regards, |
[2019-09-16 13:24:28] |
You need to set the Value Increment Per Bar in Ticks correctly in the Chart >> Chart Settings and this explains how to do that: Chart Drawing Tools: Drawing a Line with a Specific Angle or Slope You would definitely want to use a value of greater than one. Maybe 10. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-16 13:24:52
