Date/Time: Sun, 02 Feb 2025 12:58:17 +0000
The Sierra Chart Futures Order Routing Service With Denali Data Feed
View Count: 1196
[2019-09-14 22:41:01] |
User703334 - Posts: 59 |
After reading through the pertinent sections regarding the SC Futures order routing with Denali feed, I have the following question: Given my current setup: 1. CQG data feed with AMP Global cost .78/roundtrip (micro E minis) 2. CME non professional cost $5/month 3. Sierra Chart Package 5 through AMP cost $25/month What would be the benefit of cancelling CQG and using the SC Futures Order Routing with Denali feed instead? I would still have to pay all costs listed in 1-3 above. Then pay an additional $20/month plus an additional .10/Roundtrip What is the benefit of the added monthly cost of switching from CQG to SC Routing/Denali feed? |
[2019-09-15 04:14:53] |
The advantage is a more reliable, more complete, and low latency data feed as compared to CQG. And very reliable connectivity as compared to CQG. These new services are not meant to save you money. They are instead meant to provide high quality services but still at a low price. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-15 04:15:39
