Date/Time: Thu, 02 May 2024 23:02:55 +0000
Change in Volume Profile setting after New SW release?
View Count: 538
[2019-09-14 06:04:05] |
User164231 - Posts: 278 |
What happened to total volume on VP? No longer available?
[2019-09-16 13:19:29] |
John - SC Support - Posts: 31334 |
We are still working on the documentation for the changes in the new version, but all the information can still be displayed. You just need to do the following: - Set the Input for Show Chart Values on Profile to one of the available options. - Set the Input for Chart Values Position on Profile to the desired option. - Set the Input for Chart Value n to be Displayed on Profile to the desired option (Volume gives the Total Volume). This allows you to better customize what and where these options are shown. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-09-16 14:52:07] |
thanks. You guys rock!
