Date/Time: Sun, 13 Sep 2026 01:40:03 +0000
FlatToFlatClosedProfitLoss
View Count: 1199
| [2019-09-13 16:28:38] |
| Marmany - Posts: 319 |
From GetTradeListEntry s_ACSTrade both FlatToFlatMaximumOpenPositionProfit and FlatToFlatMaximumOpenPositionLoss are available but only ClosedProfitLoss is there (i.e. value for last exit). The Trade Activity log has a FlatToFlat Profit/Loss column. Is it possible to add FlatToFlatClosedProfitLoss to s ACSTrade? Please advise |
| [2019-09-16 11:05:58] |
What you need to do instead is use this new function: Automated Trading From an Advanced Custom Study: sc.GetFlatToFlatTradeListEntry() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-11-14 21:00:36] |
| ForgivingComputers.com - Posts: 1238 |
Automated Trading From an Advanced Custom Study: sc.GetFlatToFlatTradeListEntry() Support: Please update this entry to include the "function it is the same as" (I assume it is sc.GetTradeListEntry). Thanks. |
| [2019-11-14 21:47:49] |
The documentation has been corrected.
| [2019-11-14 23:23:00] |
| T44 - Posts: 363 |
If someone has time: How would I convert this to get the flat to flat P&L rather than the final contract which was closed in a multi lot position? s_SCPositionData FillData;
RetVal = sc.GetTradePosition(FillData); LastTradeProfitLoss = FillData.LastTradeProfitLoss; Thanks. |
| [2019-11-15 03:39:18] |
You would use this function and get the very last flat to flat trade: Automated Trading From an Advanced Custom Study: sc.GetFlatToFlatTradeListEntry() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-11-15 16:16:02] |
I am testing the Get Flat to Flat TradeList using the example given for sc.GetTradeList Entry, but modifying the two function names like this: std::vector <s_ACSTrade> TradesList; s_ACSTrade TradeEntry; int Size = sc.GetFlatToFlatTradeListSize(); // <------------------ Here for (int Index = 0; Index < Size; Index++) { if (sc.GetFlatToFlatTradeListEntry](Index, TradeEntry)) // <----------- and Here TradesList.push_back(TradeEntry); } for (unsigned int TradeIndex = 0; TradeIndex < TradesList.size(); TradeIndex++) { double ProfitLoss = TradesList[TradeIndex].ClosedProfitLoss; } My results in sim after one trade using this code do not match the ClosedPL from the Trade Activity Log. Am I doing something wrong? |
| Attachment Deleted. |
| [2019-11-16 12:55:18] |
Check these field values and make sure they match with the Trade Activity Log: SCDateTime OpenDateTime; SCDateTime CloseDateTime; int TradeType; // +1=long, -1=short t_OrderQuantity32_64 EntryQuantity; t_OrderQuantity32_64 ExitQuantity; double AverageEntryPrice; double AverageExitPrice; Also refer to: Trade Activity Log: Understanding and Setting the Start Date-Time for a Trades List Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-16 12:55:33
| [2019-11-18 17:32:26] |
Thanks for this. I checked the numbers and they matched. It turns out I needed to do the currency conversion for the Forex Pair.
