Date/Time: Sun, 02 Feb 2025 15:57:12 +0000
LMAX
View Count: 879
[2019-09-13 16:17:01]
mjhjava - Posts: 7
Whilst I can connect to the 'LMAX - Live Trading- DTC' I appear to be unable to connect to the LMAX Trading -FIX' Data Feed. Can you explain what my issue is or alternately suggest a course of action?
Thanks.
[2019-09-16 05:52:17]
Could you let us know why you want to use the FIX connection directly? We are not sure why there is a problem but we do not provide technical help for directly using the FIX connection.
[2019-09-16 06:49:34]
mjhjava - Posts: 7
In order that I can use INTELLIGEX's algo software.
[2019-09-16 09:25:19]
This would not be a valid reason. You do not need to use the direct FIX connection and we do not recommend that.
[2019-09-16 10:35:17]
mjhjava - Posts: 7
I'm sorry? I have misunderstood your answer perhaps. INTELIGEX recommend Sierra for their plug-in, which is why I bought a year's subscription, so what are you talking about?
[2019-09-16 11:00:03]
You must use the 'LMAX - Live Trading- DTC' Service which you said is working for you. So there is nothing further you need to do. You are all set in this regard. There is no problem here. You are all set.
[2019-09-16 12:41:45]
mjhjava - Posts: 7
Then what is the 'LMAX Live Trading- FIX Trading' Data feed (to which I cannot connect) if it's not for use with FIX and the LMAX Brokerage?
[2019-09-16 13:28:02]
That is a service you do not want to use. You do not need it and we do not provide any technical help for it. Just ignore it.
[2019-09-19 07:58:25]
mjhjava - Posts: 7
Please excuse my stupidity...
So- I am assuming that if I 'uncheck' the 'Trade > Trade Simulation Mode On' box my Live LMAX Account will be automatically connected by FIX to INTELIGEX add-in?
Regards
[2019-09-19 08:33:34]
Disabling Trade Simulation Mode means that the orders are then live rather than internally simulated in Sierra Chart. In either case though, the INTELIGEX add-in you are using is still functional.
Date Time Of Last Edit: 2019-09-19 08:33:47
[2019-09-20 00:35:22]
mjhjava - Posts: 7
Then why are the Instruments shown on both LMAX Sierra feeds and listed on the LMAX London website not replicated?
[2019-09-20 08:35:39]
We are not understanding the question. Are you referring to orders that you see on LMAX website not showing up in Sierra Chart? You can see the orders through Trade >> Trade Orders Window within Sierra Chart for your account.
But if those orders were submitted before the LMAX account assignment was done to your Sierra Chart account, you will not see them.
Date Time Of Last Edit: 2019-09-20 08:36:08
