Date/Time: Sun, 02 Feb 2025 14:49:20 +0000
Flatten button in the chart
View Count: 760
[2019-09-13 14:51:59] |
User710679 - Posts: 43 |
Hi, is there any way to insert a FLATTEN button (maybe using a study?) in the chart instead of having to attach the trade window to the chart?? thanks! David |
[2019-09-13 15:27:31] |
Ackin - Posts: 1865 |
Global settings / Customize control bar / Control Bar 1 .... in the left list / Trading commands / "Trade Flatten and Cancel" ......and the use ADD button in the middle to add this item to right side to your user-buttons Control Bar Date Time Of Last Edit: 2019-09-13 15:36:41
[2019-09-16 09:35:12] |
You can add a menu command for this: Global Settings Menu: Customize Chart Trade Menu (Global Settings menu) Or a Control Bar button for this: Control Bar For the control bar, refer to the Trading Commands sublist. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
