Date/Time: Sat, 19 Sep 2026 10:50:20 +0000
sub instance settings sharing
View Count: 907
| [2019-09-13 11:59:08] |
| stphnlwlsh - Posts: 26 |
I searched the forum and docs, but maybe I'm not searching for the right thing. I've customized my graphics settings, keyboard shortcuts, and control bars pretty heavily on my first instance, but I'd like to be able to share those settings with my sub instance. Sym-link does not work, it creates a gigantic mess...found that out the hard way. Is this possible? |
| [2019-09-13 23:23:52] |
Yes, you just have to copy the file Sierra3.cfg from your main instance folder to the sub-instance folders. Refer to the following documentation, although you just need the one file for the configuration: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-13 23:34:24
