Date/Time: Thu, 02 May 2024 13:59:40 +0000
Nonzero Bid&Ask Vol at High/Low Highlight & Extension Lines
View Count: 931
[2019-09-13 05:09:31] |
Eddie - Posts: 12 |
Hi, I added Nonzero Bid&Ask Vol at High/Low Highlight & Extension Lines into Number Bars study and was able to see the lines on chart. However, I failed to draw the data to Spreadsheet study. Zero values at column "AC" per the attached excel are shown. Please help. Thanks |
Private File |
[2019-09-13 05:15:15] |
Extension lines do not have any value which is contained in a Subgraph and therefore outputted to a spreadsheet column.
[2019-09-13 05:28:06] |
Eddie - Posts: 12 |
To confirm my understanding, you mean the data can't be extracted to Spreadsheet?
[2019-09-13 07:00:11] |
Yes.
[2019-09-18 05:36:40] |
Eddie - Posts: 12 |
Instead of using spreadsheet trading, if I want to get all Bid x Ask volume at each price of each bar in Numbers Bars study, does ASCIL have the function for it?
Date Time Of Last Edit: 2019-09-18 05:37:19
[2019-09-21 00:13:30] |
Refer to: ACSIL Programming Concepts: Accessing Volume at Price Data Per Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
