Date/Time: Sun, 02 Feb 2025 12:42:12 +0000
modum firewall
View Count: 531
[2019-09-12 19:47:44] |
User727587 - Posts: 13 |
1. what modum portnumbers can be opend to share with sc. in order to get minimum lag. 2. maybe you can say some more about settings that give optimal com. reason to ask: orders are executed before sc data reaches time price. |
[2019-09-13 08:19:25] |
We see you are using the Sierra Chart Exchange Data Feed. If you are noticing any lag, refer to help topic 4.12 to try a couple of things which may help: Prices / Data Falling Behind: 4.12 - Sierra Chart Exchange Data Feeds Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
