Date/Time: Sun, 02 Feb 2025 12:58:13 +0000
Chart does not print candles properly
View Count: 696
[2019-09-12 16:20:12]
User170075 - Posts: 8
chart is delayed and prints gaps between candles and all sorts of weird candles. link below
http://www.sierrachart.com/image.php?Image=1568296600382.png
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=31409
[2019-09-12 22:28:00]
You are using Rithmic.
Use the Sierra Chart Historical Data Service and see if you still have the problem for that chart. Refer to:
Sierra Chart Historical Data Service: Setup Instructions
You will need to change the symbol of the chart to match that service and you can easily do that:
Changing the Symbol of a Chart
Date Time Of Last Edit: 2019-09-12 22:28:17
