Date/Time: Thu, 02 May 2024 21:35:55 +0000
ACSIL Alert Audio and Logging
View Count: 749
[2019-09-12 15:00:11] |
kas64h - Posts: 87 |
From within ACSIL: 1) Can an Audio Alert (or any audio), be played without submitting a message to the Alert Log (sc.PlaySound() seems to always add a message to this log) 2) Can the 'Mute All Alert Sounds' status be established Thanks. |
[2019-09-12 22:17:52] |
No and No.
[2019-09-17 08:27:17] |
As I'm playing multiple audio files for some alerts, is there any possibility that either one of these could be implemented? Thank you. |
