Date/Time: Sun, 24 Nov 2024 23:07:10 +0000
Millisecond equalent for currentbar date & time
View Count: 1483
[2013-12-11 22:49:09] |
ejtrader - Posts: 688 |
SC Team - On few of the occassions, noticed the crossbar time would display the bar datetime rounded to seconds and CTV(compact tool window displays in milliseconds). Would it be possible to update crossbar timestamp to match up CTV value? Also - is there any millisecond equivalent of sc.BaseDateTimeIn[sc.Index] ( assuming at present this is rounded to "seconds" )? Basically wanted to compare it with SCDateTimeMS type accurately. Thanks |
[2013-12-13 01:31:40] |
We will be providing documentation for this. We will try to get to it within the next day.
[2013-12-14 00:59:08] |
Refer to the documentation here: https://www.sierrachart.com/index.php?l=doc/doc_ACSILProgrammingConcepts.html#AccessingMilliseconds Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-12-14 18:21:35] |
Thanks SC Team. Considering Millisecond timestamps - Is this the correct way to detect if a T&S record belong to the last bar on chart ( irrespective of the chart type )? Thanks .. sc.AutoLoop = 1; .. SCDateTimeMS cbDT = sc.BaseDateTimeIn[sc.Index]; SCTimeAndSalesArray TimeSales; sc.GetTimeAndSales(TimeSales); for (int TSIndex = TimeSales.GetArraySize() - 1; TSIndex >= 0; --TSIndex) { SCDateTimeMS TradeDateTime = TimeSales[TSIndex].DateTime; if (TradeDateTime >= cbDT) // Will this ensure the T&S record belongs to the very last bar on chart irrespective of the chart type? { // Few actions } } Date Time Of Last Edit: 2013-12-14 18:26:23
[2013-12-16 16:53:13] |
This looks fine, but you need to apply the time offset to get the Date-Time set to the time zone setting: SCDateTime TempDateTime=TimeSales[TSIndex].DateTime;
TempDateTime += sc.TimeScaleAdjustment; // Apply the time offset Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
