Date/Time: Sun, 02 Feb 2025 12:46:32 +0000
Automatically adjust OCO orders to actual fill price when entering at market
View Count: 623
[2019-09-12 14:28:19]
User972768 - Posts: 166
I've noticed on multiple occasions that my attached orders do not work at their best when I enter at market. It seems that they are set according to what Sierra thinks is "current" price instead of actual fill. Is there a way to automatically adjust attached orders to my fill price or average price of the position?
Thanks and best regards
[2019-09-12 17:02:31]
You need to enable this setting:
Global Trade Settings Windows: Adjust Attached Orders to Maintain Same Offset on Parent Fill (Global Settings >> General Trade Settings >> General)
And you must disable this setting:
Global Trade Settings Windows: Use Server Side Bracket Orders (if supported) (Global Settings >> General Trade Settings >> General)
If you want server-side bracket orders to work as you expect, use this service:
Sierra Chart / Trading Technologies Futures Order Routing Service
Date Time Of Last Edit: 2019-09-12 17:03:06
