Date/Time: Tue, 29 Sep 2026 07:17:06 +0000
CQG Connection Error
View Count: 784
[2019-09-12 13:58:42]
User728808 - Posts: 12
No issues this week, and suddenly this morning I haven't been able to connect to data feed. Error log attached below.
Reading Internal Order ID file. | 2019-09-12 06:47:21.782
Reading Trade Orders file. | 2019-09-12 06:47:21.895
Reading Trade Positions file. | 2019-09-12 06:47:21.895
Reading Account Balance file. | 2019-09-12 06:47:21.896
UDPListener (1392). Port 22904 | Listening on UDP port 22904. | 2019-09-12 06:47:21.921
Software version: 1983 64-bit | 2019-09-12 06:47:21.921
Enabled for: Advanced Features 2. | 2019-09-12 06:47:21.921
Enabled for: Sierra Chart Historical Data Service. | 2019-09-12 06:47:21.921
Allow Support for Sierra Chart Data Feeds is enabled. | 2019-09-12 06:47:21.921
Current selected Data/Trading service: CQG WebAPI | 2019-09-12 06:47:21.921
Custom symbol settings values: disabled | 2019-09-12 06:47:21.921
Chart Update Interval: 500 | 2019-09-12 06:47:21.921
Intraday Data Storage Time Unit: 0 | 2019-09-12 06:47:21.921
Time Zone: -07:00:00 (MST-07) | 2019-09-12 06:47:21.921
2019-09-12 06:47:21 Local computer time | 2019-09-12 06:47:21.921
2019-09-12 13:47:21 Local computer time in UTC | 2019-09-12 06:47:21.921
2019-09-12 06:47:21 Local computer time in SC Time Zone | 2019-09-12 06:47:21.921
2019-09-12 13:47:20 Server time in UTC | 2019-09-12 06:47:21.921
Local computer UTC time and Server UTC time difference: 1 seconds. | 2019-09-12 06:47:21.921
Program path: C:\SierraChart\ | 2019-09-12 06:47:21.921
Data Files path: C:\SierraChart\Data\ | 2019-09-12 06:47:21.921
OS Version Number: 10.0 | 2019-09-12 06:47:21.921
Locale Setting: C | 2019-09-12 06:47:21.921
DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-09-12 06:47:21.922
Checking for new symbol settings. Requested symbol settings MD5 for service code cqg. Request ID: 1. | 2019-09-12 06:47:21.922
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-09-12 06:47:21.945
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-09-12 06:47:22.105
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-09-12 06:47:22.105
Received 5 login tokens. | 2019-09-12 06:47:22.514
Symbol settings MD5 received. Request ID: 1. | 2019-09-12 06:47:22.683
Requested symbol settings for service code cqg. Request ID: 2. | 2019-09-12 06:47:22.684
Symbol settings received. Request ID: 2. | 2019-09-12 06:47:23.603
CQG WebAPI | Connecting to server api.cqg.com | 2019-09-12 06:47:27.665
CQG WebSocket | Connecting to WebSocket server. | 2019-09-12 06:47:27.665
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-09-12 06:47:27.666
CQG WebSocket socket (1) | Connecting to IP: 208.48.16.35. | 2019-09-12 06:47:27.667
Service is currently connecting. | 2019-09-12 06:47:28.622 *
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-09-12 06:47:33.482 *
CQG WebSocket | WebSocket closed. | 2019-09-12 06:47:33.482
CQG WebAPI | WebSocket closed. | 2019-09-12 06:47:33.483
CQG WebSocket socket (1) | Closed. | 2019-09-12 06:47:33.483
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-12 06:47:33.483
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-12 06:47:33.483
CQG WebAPI | Disconnected. | 2019-09-12 06:47:33.493
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-12 06:47:33.493
CQG WebAPI | Connecting to server api.cqg.com | 2019-09-12 06:47:36.501
CQG WebSocket | Connecting to WebSocket server. | 2019-09-12 06:47:36.501
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-09-12 06:47:36.503
CQG WebSocket socket (1) | Connecting to IP: 208.48.16.35. | 2019-09-12 06:47:36.503
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-09-12 06:47:46.323 *
CQG WebSocket | WebSocket closed. | 2019-09-12 06:47:46.323
CQG WebAPI | WebSocket closed. | 2019-09-12 06:47:46.323
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-12 06:47:46.323
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-12 06:47:46.323
CQG WebSocket socket (1) | Closed. | 2019-09-12 06:47:46.323
CQG WebAPI | Disconnected. | 2019-09-12 06:47:46.328
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-12 06:47:46.328
File >> Disconnect selected. | 2019-09-12 06:47:46.594
CQG WebAPI | Disconnected. | 2019-09-12 06:47:46.594
[2019-09-12 14:01:29]
EDIT: The problem has resolved itself. Must have been an error on CQG side. This ticket can be closed.
[2019-09-12 16:39:07]
We recommend using this service instead of CQG:
Sierra Chart / Trading Technologies Futures Order Routing Service
