Date/Time: Sun, 02 Feb 2025 12:51:06 +0000
NO BID ASK
View Count: 801
[2019-09-12 13:23:59] |
Crtfyd - Posts: 281 |
I downloaded current version yesterday. It didnt connect and support here said tell TransAct to engage websocket[?]. That worked and it connected. But now I see I dont have any Bid/Ask for my B/A Difference study, or Cumm B/A. |
[2019-09-12 15:34:36] |
In particular, The "Bid/Ask Depth Bars" Study doesnt work now on this version. I use Difference, and Cummulative Difference Inputs. But it seems none of the options work. I am getting bid ask prices though.
Date Time Of Last Edit: 2019-09-12 15:36:01
[2019-09-12 15:46:03] |
The Transact websocket connection does not provide market depth data. Only the top of book. But you should still see bars based on the top of book. We are looking into this now. So you have other studies based on this study? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-12 15:46:16
[2019-09-12 16:05:47] |
Ok we looked into this, the problem is the new Transact websocket data feed does not even provide best bid and ask size data either.
[2019-09-12 18:03:44] |
So whats the solution?
[2019-09-12 18:47:02] |
FYI: Just got off phone with Transact. He had me revert back to version 1941 (last one to work before new socket) and Bid/Ask works fine. He said first time he's heard of it. He said stay on this version until further notice. So you guys can do your stuff wherever the problem may be.
[2019-09-12 23:45:56] |
Nothing we have to do here. Transact simply does not provide market depth data with their websocket connection.
