Date/Time: Sun, 24 Nov 2024 21:25:20 +0000
Search support board
View Count: 1270
[2013-12-11 21:15:31] |
SgtJ - Posts: 154 |
Are there plans to enable easier/more thorough searching capabilities of the new support board? If I search for my own posts, some of the more recent ones don't show at all in the results (and the results only show 3). Maybe a feature in the user CP that shows all recent threads?
[2013-12-11 21:25:38] |
When you search for your own posts. What are you searching for exactly?
[2013-12-11 21:34:45] |
SgtJ - Posts: 154 |
My user handle...SgtJ
[2013-12-11 21:42:18] |
Sawtooth - Posts: 4120 |
I'd like to be able to search for keywords and usernames.
[2013-12-12 21:03:00] |
We will be adding the capability to search by displayed username.
