Date/Time: Sun, 02 Feb 2025 12:53:22 +0000
Mapping a Symbol - Eurex STOXX Banks
View Count: 841
[2019-09-12 08:09:53] |
User105664 - Posts: 4 |
Hi, Would it be possible to map; FESB (STOXX Banks) for CQG? The symbol info is as follows; ESB Euro STOXX Banks -- EUREX F.US.ESB Eurex (was DTB) (EUR) Future HMUZ https://www.cqg.com/partners/exchanges/tradable-symbols?search_api_views_fulltext=stox Thank you, |
[2019-09-13 08:18:24] |
We will set this up.
