Date/Time: Sun, 02 Feb 2025 12:55:20 +0000
[Programming Help] - Study Subgraphs Divide Ratio
View Count: 604
[2019-09-12 05:26:38]
nicktrader - Posts: 734
As you can see in the pic the Study Subgraphs Divide Ratio is placed under the NBs in Region 1.
I would like to change it and set it in Range 2 above NB calculated values and the figures should be displayed as a table in one line (alternative in region 3 but also in one line).
Is that possible?
imageStudy Subgraphs Divide Ratio.png / V - Attached On 2019-09-12 05:16:54 UTC - Size: 10.97 KB - 233 views
