Date/Time: Sun, 02 Feb 2025 13:00:24 +0000
[User Discussion] - Chartbook Groups: Possible instructions improvement
View Count: 597
[2019-09-11 23:04:56]
Kiwi - Posts: 375
Thanks for this excellent new feature.
I followed the instructions (under Wine/Linux) but deviated at one point. Rather than copy the .cht files I sym linked them. As a result, when I alter a chart within the opened group it changes the original chartbook.
You explicitly copy the originals then say changes won't be replicated. Does that mean that symlinks don't work in windows? If they do, why not add to the instructions because its more useful in most situations if you don't create multiple chartbooks dependent on the path you used to access them.
Just a thought.
