Date/Time: Sun, 02 Feb 2025 12:49:52 +0000
Calculated values - vol per sec
View Count: 1519
[2019-09-11 21:11:04] |
asetnes83 - Posts: 21 |
How can I set the drawing for the volume per second under calculates values to draw as a bar?
[2019-09-12 02:03:34] |
Acro - Posts: 441 |
One suggestion for how you can achieve this - there may be much better ones than this. Add the study called "summation of study subgraph - periodic" to this chart and choose the NBCV study and vol/sec study subgraph as the SG to be summed and then as the display choose a bar of your desired width instead of the default line. If it is the same chart you are displaying on then a period of 1 would be the appropriate setting for the summation study |
[2019-09-12 04:26:45] |
Use this study: Study Subgraph Reference And then set the Subgraph Draw Style as you require. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
