Date/Time: Sun, 02 Feb 2025 12:41:02 +0000
General SC licence and SC data Feeds questions
View Count: 547
[2019-09-11 21:06:57] |
wwwingman - Posts: 185 |
The normal license for SC allows "2 systems". Does this means I can have as many simultaneous instances as I want as long as they are on the same machine/account ? For ex, I could run simultaneously 5 instances on one machine and 5 on another machine ? Denalli feed is allowed for "Two simultaneous connections". Does this mean I can use the feed on 2 SC systems, or on 2 SC instances ? And, is it possible to have more than 2 simultaneous feeds ? For ex, if I choose to increase the SC license to 3 or 4 systems. At what cost ? (the data feed). Thx. -- W |
[2019-09-12 03:57:55] |
Refer to: Sierra Chart Purchase and License Information: Licensing / Number of Systems Denalli feed is allowed for "Two simultaneous connections". Either.Does this mean I can use the feed on 2 SC systems, or on 2 SC instances ? And, is it possible to have more than 2 simultaneous feeds ? For ex, if I choose to increase the SC license to 3 or 4 systems. At what cost ? (the data feed).
Yes this is supported with the Sierra Chart Exchange Data Feed:Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
