Date/Time: Sun, 02 Feb 2025 13:01:04 +0000
Gap in CQG data with AMP futures
View Count: 528
[2019-09-10 22:10:50] |
User232042 - Posts: 35 |
Hello, I seem to have a gap in my futures data from CQG & AMP and I've double-checked my session times many times to make sure it wasn't a small mistake. I'll post a link below and upload an image of my settings as well. Also, I've been trying to get volume bars to show up on my DOM, I went to Global settings -> Chart DOM settings -> Current volume bars length relative to bid/ask, and nothing comes up. The only thing I can get to appear from this menu on my DOM is Display DOM depth totals. Thanks in advance, I am fairly new to the platform so it may be a stupid mistake on my end. http://www.sierrachart.com/image.php?Image=1568152724123.png Date Time Of Last Edit: 2019-09-11 03:13:43
Screen Shot 2019-09-10 at 3.00.53 PM.png / V - Attached On 2019-09-10 22:01:56 UTC - Size: 185.49 KB - 212 views |
[2019-09-11 07:52:06] |
Regarding the missing data, follow through the instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart To show volume bars for a particular Chart/Trade DOM column, refer to: Global Trade Settings Windows: Show Volume Bars (Trade >> Customize Chart/Trade DOM Columns) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-11 07:52:48
