Date/Time: Sun, 19 May 2024 12:01:45 +0000
Continuous contract roll
View Count: 561
[2019-09-10 18:13:34] |
arruga - Posts: 249 |
Hi Please see this chart, set with continuous contact, volume-based, back adjusted It doesn't seem to be calculating correctly, giving me a huge Gap on roll date. http://www.sierrachart.com/image.php?Image=1568139020942.png I tried delete/download and recalculate. Same result Please advise thanks |
[2019-09-10 21:45:34] |
Follow through the instructions here to re-download data for the last two contract months: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data And check the Message Log to make sure there are no errors during the data downloading : Message Log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-10 21:46:11
