Date/Time: Sun, 19 May 2024 10:07:14 +0000
Usage renewal
View Count: 452
[2019-09-10 17:37:02] |
User845611 - Posts: 13 |
I will not use any charting for a while and have decided to not use SC for a month or probably 2 mo. Do you need this notification or should I just not renew?
[2019-09-10 21:58:46] |
This is all fully documented here: Sierra Chart Purchase and License Information: Suspending Usage Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
