Date/Time: Sun, 19 May 2024 10:07:09 +0000
Tick Counter Question
View Count: 1043
[2019-09-10 15:09:22] |
User718585 - Posts: 32 |
Is there a way to put a tick counter on my charts that will show me how many ticks there are in a 1-hour range. Thanks |
[2019-09-10 22:26:25] |
You need to use a combination of these studies: - Period OHLC - Variable Period - Study Subgraphs Subtract - Study Subgraph in Ticks - Text Display for Study Refer to the following for each of these studies: Previous/Period OHLC-Variable Period Study Subgraphs Subtract/Difference Study Subgraph In Ticks Text Display For Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-10 22:26:57
