Date/Time: Sun, 24 Nov 2024 22:35:20 +0000
[User Discussion] - Source Code
View Count: 1378
[2013-12-11 15:31:58]
100 - Posts: 147
I am looking to acquire a study with a source code that relates to the Vertical (Y Axis).
I would like to use this as a template. Does anyone know of a study with this feature?
Does Sierra Offer any help to into learning new templates?
Does Sierra have any example studies which compile aggregate data into a y axis formation?
Date Time Of Last Edit: 2013-12-11 15:34:50
[2013-12-11 18:19:10]
We need more details as to what you want to do with the Y-axis. The y-axis is controlled by the Scale Range Type:
http://www.sierrachart.com/index.php?l=doc/doc_Scaling.html
[2013-12-15 10:12:15]
100 - Posts: 147
I would like to see a study or example which locates y axis units. As it is right now - I am having a very difficult time realizing how to refer to these units, let alone with functions such as trendlines or horizontal lines. Any help would be much appreciated. Considering I'm learning to code on Sierra, and the lack of examples, etc, I feel like I'm reading in circles.
Date Time Of Last Edit: 2013-12-15 10:12:32
[2013-12-15 19:42:25]
vegasfoster - Posts: 444
If you haven't, check BigMikeTrading.com, there might be something there you can look at.
[2013-12-15 22:10:20]
This is not completely clear what you are looking for. However, it sounds like you would be interested in the sc.TickSize member of ACSIL:
http://www.sierrachart.com/index.php?l=doc/doc_ACSIL_Members_Variables_And_Arrays.html#scTickSize
[2013-12-16 05:56:33]
100 - Posts: 147
Thank you guys very much. I will look into these!
[2013-12-17 01:40:35]
I thought he was talking about something like the volume by price study, but I could be wrong.
