Date/Time: Sun, 19 May 2024 12:15:04 +0000
How to set loading limit to Market depth
View Count: 504
[2019-09-10 05:15:47] |
User392279 - Posts: 67 |
Hi, too me only one or two days data stored will be enough. Don't want load too much data cause the chart not very responsive. Thanks. |
[2019-09-10 08:23:27] |
Refer to this setting: Chart Settings: Maximum Market Depth Data Days to Load (Chart >> Chart Settings >> Market Depth menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
