Date/Time: Sun, 19 May 2024 12:35:40 +0000
OCO buy stop sell stop, turn into buy stop-limit sell stop-limit
View Count: 595
[2019-09-09 21:16:33] |
Jose Carlos Ramirez Ramirez - Posts: 1 |
Good Afternoon I sent an OCO buy stop sell stop order, but the orders I got were stop limits, I use SC order routing service with Advantage Futures; Do you know if this is normal, some kind of server modification of my order? When paper trading on sim mode the oco buy stop sell stop order returns simple stop orders, it does not turn them into stop limits. |
[2019-09-10 03:06:16] |
Refer to the following: Order Types: Stop Orders on the CME Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-09-10 23:04:25] |
JaguarPaw - Posts: 4 |
I had the same issue and changed the DOM chart settings to BuyStopLimit and SellStopLimit check attachment
DOMsettings.PNG / V - Attached On 2019-09-10 23:02:05 UTC - Size: 37.89 KB - 208 views Attachment Deleted. |
