Date/Time: Sun, 19 May 2024 10:20:42 +0000
Text at top/bottom of bar
View Count: 857
[2019-09-09 18:49:50] |
User392279 - Posts: 67 |
Hi, I just seen a video on Youtube as attached. What study is that to show text at top and bottom of the bar? I know that ask/bid difference text and Bar delta below bar study. But the one in picture seems different. Any guess?
2019-09-10_024431.png / V - Attached On 2019-09-09 18:49:40 UTC - Size: 253.67 KB - 299 views |
[2019-09-10 05:12:11] |
Issue resolved. Thanks.
[2019-09-10 08:35:49] |
There is the Study Subgraph Above/Below Bar As Text study. Refer to the following: Study Subgraph Above/Below Bar as Text Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
