Date/Time: Tue, 22 Sep 2026 22:51:08 +0000
[Programming Help] - Color Bar Alert Code Help Needed
View Count: 1004
[2019-09-09 18:26:45]
User718585 - Posts: 32
I'm trying to do an Alert for the following and I just can't figure out how to write it out.
I need an alert for when the 1-hour opening range price is less than or equal to 17 ticks.
How would I write that out?
[2019-09-09 18:47:10]
My 1-Hour Opening range "Initial Balance Study" is ID.13, SG7(HIGH) and SG9(Low)
[2019-09-09 19:16:02]
Sawtooth - Posts: 4354
Try this:
=AND(BARTIME>TIMEVALUE("10:30:00"),(ID13.SG7-ID13.SG9)/TICKSIZE<=17)
where the open is at 09:30:00; edit time between quotes as needed.
[2019-09-09 19:29:17]
Man that works perfect. Thank you so much!!
