Date/Time: Sun, 19 May 2024 13:39:05 +0000
DATA AND CONNECTION PROBLEMS
View Count: 499
[2019-09-09 18:06:39] |
D WING - Posts: 2 |
Hi, I have IQFeed, but their data is intermittent when used with the Market Depth Historical Data study. It was fine all last week, now doesn't work at all. I use NT and NT Brokerage concurrently, so I asked them for data through their CQG/Continuum service, for which they provided an additional login. I have been unable to make this connection. Do you have any instructions or suggestions? I tried looking through the support forum, and calling NT Brokerage, to no avail. Thank you, Doug |
[2019-09-09 18:17:09] |
You should be using one of these two data feeds instead of IQ Feed: Sierra Chart Exchange Data Feed Denali Exchange Data Feed Regarding ninja trader, refer to: Using Sierra Chart with Ninja Trader Brokerage Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-09 18:17:38
