Date/Time: Sun, 19 May 2024 11:41:15 +0000
Control Bar and Trade Window Config File Syncing
View Count: 566
[2019-09-09 03:04:46] |
User379468 - Posts: 508 |
How can I sync control bar configuration and trade window config files between instances?
[2019-09-10 01:37:32] |
Even manually if needed, how can I load an already configured control bar into another instance without constructing it over again from scratch or having all my other settings overwritten?
[2019-09-10 10:46:21] |
Refer to the following information for how to copy the information between installations and what files contain what information. The Trade Window Configuration files are in the Data folder and end with .twconfig. Transferring Sierra Chart Settings and Data From Existing Installation to New Installation You must also copy files when Sierra Chart is not running. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-09-10 16:56:36] |
Sierra.cfg worked to copy control bars but overrode the files to open on startup settings for different instances, hopefully no other important settings were overridden. Would be useful if possible to save/load some of these settings independently/easily without overriding others.
Date Time Of Last Edit: 2019-09-10 16:57:20
[2019-09-10 19:30:54] |
This is not possible. And would never come.
