Date/Time: Sun, 19 May 2024 14:54:43 +0000
Replay Isn't working, Replay Control Panel doesnt load anymore
View Count: 527
[2019-09-08 04:39:17] |
TropicalTrader - Posts: 37 |
Hi, I was using replay a couple weeks ago. I tried it this eve on the same computer/sierra installation and the control panel doesn't open. Whether I use the shortcode or chart > replay chart > replay chart I just upgraded my sierra from 1975 to 1986 and restarted my computer. I also tried loading a single chart, nothing happens when I try to launch replay control panel.. |
[2019-09-08 04:54:50] |
Refer to: Replaying Charts: Chart Replay Window Not Visible Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
