Date/Time: Fri, 18 Sep 2026 21:59:57 +0000
Scanner or study summary displaying closest subgraph level to current price
View Count: 1054
| [2019-09-08 00:36:13] |
| User161560 - Posts: 19 |
Hi - I'd like to create a study summary or scanner that displays in real-time where price is in relation to subgraph levels on my chart. I have a custom study with 25 subgraphs plotted on the chart as horizontal lines and I want to see on a separate window, such as a study summary or real-time spreadsheet, where price is in relation to those subgraphs e.g. if price is closest to subgraph 1 then the study summary/sheet would print the name of subgraph 1. Then if price moves up and becomes closest to subgraph 2 the summary would update in real-time and change to display the name of subgraph 2 etc. Then when I've got that going for one chart I can add different charts and products to the scanner/spreadsheet display. This seems like it should be really easy, but I got stuck at alert conditions and haven't managed to find a solution. Any ideas would be greatly appreciated. Many thanks! Best, Simon |
| [2019-09-08 10:30:29] |
| Ackin - Posts: 1865 |
Hi, I was doing something similar ... for your case it would probably have to be modified a little bit, but otherwise it's probably what you're looking for. Adding OHLC Subgraphs to Number Bars Calculated Values |
| [2019-09-08 14:05:06] |
Thanks Ackin. I really want to create this study myself rather than rely on a custom study that I can't modify, but thanks again for the suggestions. Cheers Simon |
| [2019-09-08 14:24:57] |
Ok. If you would need help with your own code in this case, write me a direct message but working with tables in ACSIL is not difficult. Look at: SCH example "scsf_NumericInformationGraphDrawTypeExample" studies8.cpp It can help you a bit with the structure of the table. |
