Date/Time: Sun, 19 May 2024 15:32:35 +0000
[User Discussion] - Replay auto trading only works with single contract
View Count: 590
[2019-09-07 02:32:37] |
asetnes83 - Posts: 21 |
When I do a simple replay while using trading system based on alert condition, it will only work with a quantity of 1. I'm unable to test a quantity of 2 with 2 different targets. How can I fix this?
[2019-09-07 06:59:33] |
Open the Trade Window for the chart and set the Order Quantity setting to what you require: Basic Trading and the Trade Window: Opening Trade Window for Chart or Trade DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-09-07 13:01:00] |
Yes I know that. I have a 2 target bracket order with a quantity of 2 and it does not execute. It does not execute a quantity of 2 even with 1 bracket.
[2019-09-09 17:43:35] |
Be sure that the value entered in the Maximum Position Allowed is 2 or greater. This sets the maximum quantity that can be set for that study. Refer to the information for this setting within this section here: Trading System Based on Alert Condition: Inputs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
