Date/Time: Thu, 01 Oct 2026 16:55:36 +0000
OHLC Bar Colors (Day session vs. evening session)
View Count: 2104
[2019-09-06 20:23:37]
User326940 - Posts: 23
Is it possible to make evening session bars one color and make the day session bars a different color on intraday OHLC bar charts?
I'd like to be able to visually see the difference between the sessions.
Thanks,
Michael
[2019-09-07 04:58:47]
Ackin - Posts: 1865
Try this, study from default Sierra chart list:
Time Range Highlight
settings of study / tabs Subgraphs -> change Drawstyle to ColorBar
[2019-09-07 06:55:44]
Use this study:
If you really want to color bars, you would have to use the Color Bar Based on Alert Condition study and then check the time of the bar for the Alert Condition. Refer to the following for the study:
Refer to the following for specific identifiers that are available to get the time of the bar, specifically the BARTIME identifier and how to use it:
Study/Chart Alerts And Scanning: Available Main Price Graph Identifiers/Variables
[2019-09-07 09:43:44]
User343901 - Posts: 66
This formula in the colour bar alert study will shade the globex session in ES. Times are CTS.
=OR(BARTIME >= TIME(15, 14, 59), BARTIME <= TIME(8, 29, 59))
[2019-09-07 17:26:09]
Thanks everybody for the timely and thoughtful responses! I'll try to make these work!
Michael
[2019-09-07 18:42:45]
Using the time range highlight study and setting the drawstyle to colorbar worked like a charm.
Thanks!
Michael
