Date/Time: Sun, 19 May 2024 16:25:52 +0000
[Programming Help] - Trade Log Problems
View Count: 549
[2019-09-06 15:52:33] |
User915231 - Posts: 4 |
I'm having problems with the trade log & DOM. I attached pictures of the DOM. In the first picture it shows that I'm up .80P, but my trade log shows nothing. I made several more winning trades & then my DOM showed 0.64P with no trades showing in the trade log. Later, the trade log showed trades. Also, having problems with the stop loss. When I drag it to the current level, it will only let me drop it below the current price on a long and above on a short. That means that I always lose one tick. It didn't seem to do that before. Additional, I've placed the stop 1 tick above or below the entry and my DOM shows a loss. Thanks for reviewing, Randy |
Private File |
[2019-09-06 16:27:14] |
There is a field at the top of the Trade Activity Log which list notes, be sure to set that to None. Also refer to: Help With Daily Profit/Loss Value Trade Activity Log: Understanding and Setting the Start Date-Time for a Trades List Regarding Stop orders, refer to: Order Types: Stop The exchange will reject certain modifications. The documentation explains this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-06 16:28:24
